cutter drag / running off on print & contour cut - voltage, blade angle or depth?
discountdecals
Hi Folks,
I'm running a tjet1671c. My 'current' prob is that it starts a cut fine but as time goess on the cut runs off. i'm cutting out motox / quad decals. 1.5m x 1.5m. If I use 2 or 3 cuts, after the first cut, the 2nd cut is say 5mm on the x and y axis off. i had thought it was initially the roller pressure was off but I honestly think it is drag.
I have my cutting voltage at 7.5, the blade depth is 1.8mm and the material is 3 layers of 4micron and a 60 degree blade. What do you all recommend?
