So right now I'm cutting some Engine Turn vinyl for some Fire apparatus. Usually I have little issue with running it through a plotter, however, this time around its a rather small and tedious design. Sections are thin around an 1/8" to 1/16" wide, what type of settings do ya'll recommend. I can manipulate speed and pressure, I just don't know how each effects the cut. I'm a bit limited on material so I'd rather not play around. Attached below is the design in question. This is what the department currently has, so I'd prefer to keep the design intact.
