Brilliant Colorworks
I have a sp540v. Been a great machine. Recent problems and attempted remedies:
1. a few black jets just quit firing right at one edge of the printhead. Cleaned several times, soaked, manually expressed cleaning fluid from syringe from top of manifold. (i chalked it up as "I need a new head" and I'm living with it.) I compensated by dialing up the print adjustment (user menu)
2. Started having intermittent pinch roller errors/ sheet setup error. Have clean the interuptor sensor on the tool carriage several times. Based on process of elimination, I have identified 2 pinch roller assemblies that are causing this problem. No issues when those are not used. I can live with that.
3. What I CANNOT live with is this, I make a lot of install patterns with the plotter/pen. Been great for years, no issues. Cutting vinyl, BIG STUFF, LONG STUFF, been great for years, no issues. NOW all of the sudden, if I have a file that say the start point and the end point should measure 100", it only measures 98". Have replaced ALL the pinch roller wheels. Environmental matched, adjusted the "hold down bar", it was starting to become easier to push down, so the media is gripping fine. I've tried adjusting the calibration both in the user menu and the service menu to no avail. I tried different medias, tried a different file. No matter what the overall length of whatever I am cutting comes up about 2" short (story of my life). The surprising thing is that all cut/drawn objects have closed paths. No gaps in any letters. Am I missing something? Would a bad cable cause this? I do need to replace some but I would think that a cable would cause this sort of problem. I am challenging anyone to help me solve this. It seems after days of reading/searching all over forums that nobody has had this problem. I do most all service work myself. Now that I have a service manual my next adventure is replacing the printhead.
Thanks in advance.
Scott
Thanks in advance.
Scott
