dampers for 1204 were to buy
biedy67
dampers replacement
ok i replaced my dampers because i was missing some black in test print so i put new dampers on and pulled ink through with a seringe and the test print is ok and the next day i do a test print and its missing some black again so i do a cleaning and black comes back but the next day im missing again?????
inkmed
maybe not damper problem, you can try find if there are problems of ink tube, cap station and ink pump.
if there are air leak, will cause the missing.
Adam Yang from Inkmed
