lbpalm
I have a couple of problems on a tradesman's van signage that I'd love to hear some feedback on.
Here it is:
Issue #1:
Clear coat is de-laminating from base vinyl - Vinyl is a/r Oracal (calendared - should I try cast?) and the clear lam is Oracal 290g.
This problem is occurring in deep grooved recesses - the areas where the side panel has steel instead of a glass side window installed in place of metal.
That deep-radius is where the vinyl construct is de-laminating; note that the base vinyl is sticking to the painted-surface recess OK & with no problems. I also should mention that the base vinyl print was air cured for over 48 hours before laminating on a seal Base 62 at 80% roller pressure.
Issue #2:
Laminate top coat is pulling away from base vinyl around the entire edge; - There is about a 1/16" area consistently all around the entire decal edge which is about 52 x 36 inch in size, where the clear lam has pulled away from the base vinyl. This is in relation to the same job mentioned above.
Any and all comments/feedback greatly appreciated!
& thanks in advance to all.
Lee.
Here it is:
Issue #1:
Issue #2:
Lee.
