Why not use cast vinyl?If it's a flat surface, I wouldn't be using cast vinyl, but be using uv protection laminate. I'm on the fence with direct uv prints, not as durable as a printed and laminated print, if laminated, you want to make sure the ink is not going to pull out of the substrate.
My to go material is Substance 2755 (Substance Incorporated) with Substance 3150 laminate.
I would be more concerned about using PVC on an exterior sign, but to answer your original question we would use something like GF 201 HTAP + 3M 8418G for this.I’m installing a 36” Sentra blade sign on an exterior store front. Is it better to direct uv print or latex print on cast vinyl with laminate and then mount that to the sign?
It's like buying grade 8 bolts to hold something lightweight together, no added benefit, just added cost.Why not use cast vinyl?
Is pvc bad for exterior signs? This compileI would be more concerned about using PVC on an exterior sign, but to answer your original question we would use something like GF 201 HTAP + 3M 8418G for this.
Whats wrong with pvc for exterior signs? The brand I’m actually using is 1” thick komacel. It says it’s for exterior signage..I would be more concerned about using PVC on an exterior sign, but to answer your original question we would use something like GF 201 HTAP + 3M 8418G for this.
