Disableing Media Cut.
Steve C.
Falcon Outdoor 46 Media Cutter.
The knife blade broke on my cutter a long time ago. I never used it much
anyway. But every time I do a nozzle check, it trys to cut afterward. Is
there some way to disable or turn off the cutter so it doesn't try to cut
after nozzle check?
randya
If you don’t have a new sheet-off blade available to replace your
blade, you can temporarily switch off the automatic sheet-off.
Press menu until you see Function.
Press Enter Function Ink Dry Time.
Press menu until you see “Media Cut : ON”
Press value + or value -: “Media Cut : OFF”
Press Enter
Press Back 2 times to go back to ONLINE Level.
You can find a manual here:
ftp://ftp.mutoh.com/Printer Information_Manuals/Falcon Outdoor/
