printimage
Does the fans always on? When the printer say ready to print does the machine power down? My fans always on even when i am not printing that is normal?
The fans turn on when there is media loaded. If the fans stay on all the time, your media sensor is probably blocked or broken. As long as you can print, there shouldn't be any bad side effects. If you are concerned you can try using compressed air to blow out the media sensor.
So it has to be plugged in and in sleep mode for it to auto clean? it is set that it clean before the job, do you think it should clean so much?The fan is on when media is loaded, off when not loaded.
If its like a VJ 1324 then yes it will Self clean in sleep mode, then go back to sleep.....there should be a setting that you can set the interval of how often it does this.....for example if have mine set to spit/clean every 12 hours in sleep mode. The fan is also off in sleep mode. keep media loaded when in sleep mode.
Clean before evey job? No thats to often. more ink spitting out ie full coverage....means more often cleaning.....i like to clean after long runs and lots ink coverage. But not every job sent to printer.So it has to be plugged in and in sleep mode for it to auto clean? it is set that it clean before the job, do you think it should clean so much?
