Dennis422
I recently bought used Falcon Outdoor 48 inches.
The tech changed both print heads but it seems that I'm getting streaks through the print while printing. I posted about it already once and I have tried changing the heat settings and tried countless profiles, same thing is happening.
What would be the best way to check if I have some clogged nozzles? When I do a nozzle check, it comes out streaky, in Magenta, light magenta and black ink (I believe that is on one head).
Should I take the heads out and soak them in cleaning solvent for a while and then try to use syringe to try to blow out the nozzles or I should try the trick with cleaning cartridges that you guys discussed on this thread (I know it was for a Roland printer, but principal should be the same).
http://www.signs101.com/forums/show...ad-back-to-life!!!-You-have-to-check-this-out!
Thanks in advance.
Thanks in advance.
