E074 ERR CR2 CURRENT
hotboxdp
I'm getting this error a few days after changing the maintenance station on my 1204. I read all the previous posts.
I've cleaned everything possible including the encoder sensor and checked all connections.
When I power up the print head starts to initialize and moves back towards home position and stops with the error.
GAC05
Quit buggin' me
If the encoder strip is clean, check the catch just to the left of the maintenance station that locks the head over the cap top. It is attached to a sheet metal strip that is easy to bend. If it is just a little bent the printer will throw up that error when it runs into it. It needs to be straight up to work.
If that doesn't work you might need to change the encoder strip. Doesn't take much to make it unreliable. A little scratch or some light ink mist will do it.
hotboxdp
I tried everything but still get the error. Finally I reinstalled the old maintenance station and it works fine. Just to be sure I installed the new station and again got the error. Defective maintenance station. Waiting for Mutoh to send a replacement.
netsol
there were no parts that are supposed to be transferred from old maintenance station to the new one?
look at item 7 carefully
netsol
then it sounds like that sensor mentioned in item 7 should be your issue
if you feel adventurous, you could see how much trouble it would be to swap the part
(if it looks like you could spend half a day adjusting the positioning, forget i said anything )
