Using a router table and a top bearing flush trim bit you can make a jig with a lazy-susan turntable. Takes a bit to set up, but you can punch out circles quite fast. Note: you have to cut squares first. If I knew where my jig was I'd post pictures. My shop is becoming the Bermuda Triangle of tools.
Roto-Zip with circle guide should work too.
