Edge/Envision test w/o software?
ChiknNutz
I have an opportunity to buy an Edge FX and Envision 375 plotter for a very good price. However, the outfit selling is merely a broker and knows nothing about it. Further, there is no software with it. My question, then, is there a way to test the printer and cutter w/o having software to drive it....something to ensure everything is working properly? Thanks.
mbarden
Hey Chris,
There are print tests built into the firmware of the Edge II. Do the following
Performing a print test
The GERBER EDGE 2 has several built-in test patterns that are used to
diagnose printing problems. If you should ever find it necessary to call
Field Service for help on solving a printing problem, they may ask you to
print one or more of these test prints and tell them what you see.
1 Press the hidden key, PRINT TEST to start the test print. The pattern
will print continuously.
2 To stop print test, press RESET.
Changing the print test pattern
1 Repeatedly press the SETUP key until the keypad display reads TEST
PATTERN followed by the test pattern number.
2 Press either VINYL SLEW key to step through the test pattern choices.
3 When your choice is displayed, press RESET to return offline.
They need to be able to load a fiol and substrate vinyl of course. One of the test patterns is a solid block and will show any head damage.
Hope this helps
Mike B
Big River Sign Co.
