Hi guys
I created 3500 labels just 7mm high x 20mm long each label contained an incrementing number. Printed just fine on the Edge FX.
I then feed the vinyl for cutting and line up the target, click 'Cut/Pounce' and the blade holder travels along the shaft all the way to the end (the keypad side of the GS15 and then travels toward the other end but stops & starts cutting about 2/3rds the way along instead of going further along to start cutting at the far end!
If I leave the cutting process to continue, the blade attemps to go beyond the cutting area (nearest the keypad side)! It's as if the whole cutting area has shifted about 1/3rd off the scale!
Anyone suggest a remedy for this? I'd be very grateful
I had a similar problem last week but for some reason, after afew attempts and pressing the reset button on the GS15Plus a couple of times, it started cutting correctly - on this occasion it didn't
_________________
John Cooper
_________________
John Cooper
