ERO Soft is double cutting.
skdave
:frustrated:We are using Ero Soft to run are Rolands and we have a contour cut problem. When we cut out a decal it double cuts. It is like it is cutting on both side of the cut line. One hair thin. Ero has no clue.
Any help will be thanked.
Dave
luggnut
i don't have CS5 so this may be a little different from CS4
but If you are using any raster effects (like illustrators drop shadow) or have a combination of rasters and vectors when you export there is a "transparency" menu that is normally grayed out it will have a box with preset "medium resolution" click the "custom" box beside it and another dialog box will pop up that will have "convert all strokes to outlines" checked... uncheck it.
when a cut contour stroke is converted to outlines it will cut both sides of the stroke that it converted to outlines.
skdave
Thank you very much for your info. We will try it tomoorrow and report the results. Thanks again.
Dave
