Falcon II outdoor Head rank
MJRKat
Hey guys and gals, I just replaced the print heads for the Black and Cyan on my Falcon II outdoor. I have the latest Firmware(Version 3.0 or something of the sort). I had it unplugged when I did the change, afterwards sucked ink into dampers with syringe(all of which I learned from searching on here, thanks to all). I am not getting any ink through those two heads. I have done numerous powerful cleaning cycles to no avail. There is no new ink present in the caps neither. I have tried looking in the Mutoh manual to see how to do the head rank, but I guess I am just having issues with getting to that point. I can get into Maintenance mode, but that's as far as I can get. Any help is greatly appreciated!
CRD
Head rank will not be the problem of sucking the inkt through!
What if you pull ink through the maintenance station/head caps with a syringe?
Paco
MJRKat
Thanks! That's a step in the right direction, I'm getting somewhere now, hadn't thought of that one, appreciate it!
CRD
If the maintenance/headcap station does not seal while the head is parked on it, it will not pull inkt. Next step would be the pump.
Clean the tubes from the capping to the pump, those the clogging quickly.
Paco
Robert M
fuse
Check the fuse on the main board for that print head. Sounds like the head may not be getting power
MJRKat
Its all good Robert, its getting ink now since I pulled through, and seems to be staying sealed pretty good. Thanks for the advice though!
