Falcon II Outdoor Media sheet vs roll setting
I was off for vacation and came back and somehow my operator got the media setting changed from roll to sheet and I can't find the documentation or setting to change it back??
HELP!
Eugene
Onyx software, but the machine starts up with the "sheet" led lit vs. the "roll" one, when we setup a roll it keeps feeding to find the "end" of the sheet, since the printer things we want to load sheet material.
I'm sure there is a simple solution, I went thru the menus and I have specified roll, but it has not changed the setting yet.
Sign Eagle
We have turned off the check material control, don't remember what it was under, will check the manual in the morning and let you know.
Headhunterx
Here you go, I hope this solves your problem:
Richard
  • Falcon-II Outdoor Operating Instructions.pdf
That was it!
Thank you very much, that one setting overrides EVERYTHING else.
We have the manual and I guess we missed that possible setting.
Thanks again, we can now run a roll of vinyl that needs to be installed before Black Friday.
