Falcon Outdoor 46 Printing Small Than Actual File
spur
Hi all....I have a Mutoh Falcon driven by flexi 8.1 and my files are not printing the correct size.
Example: Design a 24 inch circle for a banner graphic, rip and print, and it prints a 22 inch circle.
Any ideas? FYI the preview in Flexi and Production Manager shows actual size.
Thanks for any suggestions.
spur
I have had similar problems... randya, is it a setting you can just turn off?
Randya....Thanks! you solved the problem.
dtdm....go into Production Manager and run a size compensation. It will print an 'L' shape that is supposed to be exactly 12" x 12". If it is off, a dialog box will allow you to input the difference and that solved my problem.
