Falcon outdoor 62 Heater problem
klemgraphics
Have been having a few issues with my rear heater and not heating evenly across the platen so I thought I would take off the cover to see if there was anything out of the ordinary going on. Well in the process I slipped with the cover which still had the wires for the front heater attached and it dropped a little ways before I caught it and pulled 2 wires loose from their solder joints on the heater.
After soldering the wires back on the heater will not heat up. I think I have the wires on correctly and I even tried it the other way.
Any suggestions?
packman
I did exactly the same thing with mine. Soldered the wires back and no heat. There's a white block on there which controls the heat. If it gets too hot it switches it off. This may need replacing. I replaced it for around £2gbp and it worked perfectly.
