Click to Support Signs101 ...
i having a problem with my black ink ive cleaned numerous times and cleaned the heads and changed the dampers still no black ink any help would be appreciated
Thanks Sedrick
check for cap tub falling off, pump tube fell off the pump inlet, clogged pump tube, failed pump tube (ink on the gears). is there ink in the capping station after each clean cycle?
