Falcon Outdoor no ink to heads
bgow
I m getting no ink to heads. cleaned and power cleaned 3x
Are there fuses to the print heads ?
How can I purge the ink lines?
phxsi
Fuses are located in the main board
Try a ink charge, make sure your waste lines aren't clogged
Give us a lil more background on the printer and specific model
chester215
Just call me Chester.
When it does the cleaning check to see if anything is coming out of the waste tubes.
If nothing is coming out then it may be the capping station or a clogged tube or something else.
If there is plenty of ink coming out, then it may be a fuse.
