Click to Support Signs101 ...
3M exterior DiNoc or create my own seamless file in Photoshop then print/lam? Light to moderate compound contours are involved. Durability is a must. Need input from folks who have done one or both.
Print & laminate. Dinoc for one would be crazy expensive and forget ever trying to remove it. The other problem with dinoc would be the rolls are only 48” wide. I am 3m preferred, and dinoc certified, so I have used both extensively.
I was looking into getting Di-Noc certified but not sure if it was worth it. What's your take on it? I'm also not sure if there is that much Di-noc business in the state is there any way to find out before making the investment for certification?
Thank you to Crystal Coast and KMC. Print and laminate is the way I'll do it then. Time to hit Photoshop and build some teak or mahogany then find a guinea pig...
