favor needed
decaldude1137
just bought a dr. head cleaning machine anyone with old clogged heads for roland sg2 that are clogged and not delaminated i could use them to test this machine i will cover shipping better than just throwing them away thx in advance
netsol
they have the best support for what chemicals you use in the unit.
it's worth a call to canada to talk to val if you run into trouble.
i find AS A RULE this whole thing is very effective if you use the unit before it is apparent you have a bad head and need to flush.
a gentle flush, periodically can be very helpful
netsol
i often will use a bottle of the flush or cleaning fluid your ink manufacturer sells
if it appears not to be working, i will add 5-10% acetone. (10% might be pushing it)
damonCA21
If the heads are already clogged, you have very little chance of recovering them with those machines. They may be helpful for very light blockages, but your printer itself can clean those just as well.
