the firmware is not the problem the ink seucrity of you vj has run out and you need to recode the system to be able to run in third party inks unless you use oem ink by mutoh. you have private message
Anybody help me with my problem? I need service manual for VJ 1204. I have SM for 1304. Best Regards. Tad
I run FW 1.15 and it allows me to boot into Service mode and clear the inti count for all the inks resetting the cards count reflecting 100%
Hello could you help me?the firmware is not the problem the ink seucrity of you vj has run out and you need to recode the system to be able to run in third party inks unless you use oem ink by mutoh. you have private message
