1ST OFF...........lets deal with the TRANSMISSION FLUID!!!!!!! DO NOT USE THIS STUFF........true it is oil.............BUT GO TO A TRANNY SHOP.......and talk to people who are in this stuff day after day!!!!! it is nasty. it contains all kinda additives, non-foaming agent, cleaning chemicals, acids to promote non-sticking of oil to case(or parts). and look at al the people working there.....RUBBER GLOVES, RUBBER APRON, RUBBER BOOTS...why???? this stuff is really poisonous!!!!!!!! i dont care what other tell ya....LISTEN TO the tranny guy.
2NDLY......fresh "natural hair brushes" are made of the same stuff on your HEAD!!!! now what would you put on your hair..........TRANNY FLUID????
in all my years i have tried most all fluids other people told me to use. FAILED...
NOW......... the simpest, easiest product to use that wont evaporate, go to a solid state, or turn to gum........IS 10 weight NON-DETERGENT MOTOR OIL.
if you cant find that use 3 in 1 oil. all you need is something to help PRESERVE the natural hair from becoming brittle or dry. 2nd thing you want is OIL IN THE HEEL of the brush......before you ever PUT IT IN PAINT!!!!
brand new brush:
1.prepare a small flat container........long enough so the brush can LAY flat in it, without the end of brush handle OR HAIR TIP hitting the ends.
2. put a thin layer of 10w non detergent oil/3 in 1 on the bottom 1/8 in. deep.......
3. palette brush hair in this till it is totally soaked, now lay it flat and leave it for a couple day. this INSURES the oil will soak into the HEEL... so when you put the brush in paint.........the paint stays in the hairs and not in the HEEL......
4. when cleaning......keep changing the mineral spirits/turps until it no longer show the paint color you was using NOW IT IS CLEAN!!!
5.WITH INDEX FINGER AND THUMB........ lightly squeeze from heel to tip to remove cleaner........lay into oil)))
