Fixing / Hanging An 8m Banner On A Wall?
solantis
Hey guys.. I've got an 8m (26 feet) banner with eyelets at every 1m (3.2 feet) and need to hang or fix this banner to the wall. The banner will need to be replaced every few months. What is the best method to fix it to the wall?
Billct2
If this is going to a constantly changing banner you should look at a system of some type that doesn't require screwing/unscrewing for every change.
Henryz suggestions are good.
Moze
Not saying it's the best, but one pretty simple method...
Install eyebolts into the wall a few inches away from the perimeter of the banner, in line with each grommet. Use zip ties to tension the banner between the eyebolts. Makes for an easy change out.
Billct2
Yea, I have some permanent banner mounts that are nothing more than eyebolts. They are smaller banners though and set up with pole pockets that have the corresponding hardware that clip to the eye bolts. Also had a pretty big banner with eyebolts & zip ties, but they always seem to get wrinkles. Depneds on the budget.
bannertime
This would be the most economical if the Ackland frames are out of question. We've had success with those tent bungees that have the plastic ball on the end of a loop. No knives or zip ties needed to change them out.
