flexi 12 print cut issue
BAD NOVA
I'm printing a job that has two screw holes inside decal,
when I go to effects it will show contour cut but wont cut holes.????
Any information will help.
Thank you
In the CutContour dialog box there should be a check box that says something along the lines of, "Cut Holes". Make sure it is checked.
IsItFasst
I think you may need to "compound" the holes into the main part of the decal so it knows it is cut out of it. Otherwise Flexi thinks you are printing that as just a circle. Or you can just select the "hole" and add the contour cut to it, then group all together. Essentially if the hole is actually a hole you should see the artboard through that area. You can change the color of the artboard to confirm that it is actually a hole as you will see through that area.
