Flexi 7.5 and Importing Illustrator Files
hooksigns
Ok after 14 years I am now switching over from my old Mac LC520 using Rolands SMS (Sign Making System Pro) and Illustrator 5 to an Imac G5 with Flexi 7.5.5 and Illustrator CS. I have been converting my Illustrator files from 5.0 files to Illustrator CS files.
When importing these CS files into Flexi they import but not at the proper size and the file is imported as one object. Constantly changing from the "select tool" arrow to the "select within tool" arrow is a painfull way to manipulate the artwork imported as I have to keep choosing the select within after each click. It is as if the ai file is imported as a group and cannot be ungrouped.
Any advise on importing Illustrator files into Flexi 7.5 would be appreciated.
Thanks in advance --Rob
iSign
Why are you bringing them into Flexi? Just to send cuts? ...if so, I would set up the cut files as needed in Illustrator if that is the program you are more familiar with.
I'm not sure why they group up, & I have little doubt that issue will get resolved, but in the meantime, if you set up cut files in Illustrator... you won't need to ungroup anything in Flexi
gvgraphics
Most AI and EPS files come in grouped. Select the object and then go to arrange-group-ungroup. That will ungroup the objects and let you select them as needed. As for the size issue, I'm not sure.
ColesCreations
Try right clicking on the selected file and "unmask" or "release clipping mask", you may have to do it several times, then you can ungroup as well.
Graphics2u
Why are you changing your ai ver 5 files to CS2? Leave them as v er 5 and they may work better with flexi.
Flexi has a free update ibelieve on the web from 7.5 to 7.6 and it seems to work better with CS2 Files in my opinion.
