Flexi 7.5 problem
axle55
I have Flexi 7.5, been using it for awhile. I used it 3 days ago & today I tried to open it, but I can only open Production Manager or Flexi 7.5 software. It won't like me have both of them open at the same time. This has happened before but I can't seem to fix it. Any suggestions?
Thanks in advance!!
scallahan
You could try resetting your preferences through the preference manager, a stand alone module found in the Flexi directory.
cgsigns_jamie
Do you have that copy of Flexi installed on another computer on the same network?
Flexi allows you to access the security dongle via a network connection. If you have one instance of Flexi/PM open on a remote computer you can only open one instance on the local computer. Check to make sure that Flexi/PM is closed on the remote computer.
If not then try restoring the default preferences via the Preference Manager as scallahan mentioned.
axle55
Thanks everyone......after 8 hours of trying to install/re-install on 3 different computers it just took off, finally! Not quite sure what I did to fix it.
THANKS AGAIN!
