Flexi issues
slappy
when i type, the kerning is always adjust to .16 in design central no matter how many times i restart it and now my space bar is going backward and it's just acting weird (even when it does space forward... it's not spacing right, it's too close to the next word). Any suggestions?
AUTO-FX
Clear preferences was always the first thing tech support used to say, particularly when I had 7.5 and 7.6
slappy
I did that a few times already in preferences. (restore default)... but with no luck.
I think i might have fixed the issue though. I went into the design central settings and reset things to "0" and restarted, then did it again and once more. Seems to have worked and the spacing issue is gone.
I've always noticed the last font i use is the first font that is used again when i open Flexi and start typing, so it must have some sort of "auto save" and i must have done something with the kerning setting and something else... Hopefully it's fixed because it's been very annoying :wink:
MikePatterson
Head bathroom cleaner.
If you select the text tool and then select a font then start typing, Flexi will save that font as default. To keep a certain font like arial as default just select the text tool and start typing. Then when done with your text, click on the "select tool" and select the text and change it to whatever font you want. The next time you click the text tool it will still be arial.
Same with default color. If you click on a color with nothing selected on the page it will change the default color to that color.
Hope I didnt confuse you too much.
