Hi.
We upgraded our Flexi software last year from 10.X to 12.X, since the endex of upgrading from Flexi 10.X was announced.
There was not much new features in the program, and all seamed very similar to the earlier version. However, there are some small things that puts some pebbles in the machinery. I.e. the processing of "Registration Marks" in the plotter driver dialog/output. In Flexi 10.X you could send a design with manually placed cut/weedlines in different colors, and then plot the file with Send all colors, single panel, single job, and the plotter would cut the Reg. Marks only once. Now in Flexi 12.X the Reg. Marks are cut once for every different color that are represented in the chosen graphic you want to plot.
Of course; you can argue that this is the way to do it, and that the old ways are.... well old, but I have several old files with special colors in the logos that is a pain to rework and get into only one color so that the Reg. Marks will only plot once when I produce these. In shorter and smaller files it is not so critical, but in logos that are 1m+ the reg. Marks do seldom look good when the plotter has returned after several length passes and plottet the Marks twice. The command that tells the plotter driver to plot the Reg. Marks once for each color in the same operation should not be so difficult to remove I think. I have asked support on this issue also, but have not got any reply. Anyone else noticed this or have any thoughts?
Best regards
Tony
Best regards
Tony
