It will depend on your curing method. What i use is one part but needs high intensity light to cure. We used a one part before we switched that cured under black light but took forever. Ours cures through a conveyor in a few minutes. They were very helpful and sent out quite a few testers for use to try out before we decided.cheers.
what products do you produce with these?
I'm doing beer tap labels, 73mm dia circles (2.8 inch) and am trying to work out the correct amount of resin to use. What would you set your output to?
Could you be more specific about the exact product and equipment you are using? I've glanced at the websites but I'm not sure where to begin. Thanks!We use Dymax (dymax.com) for our resins. We go through about 30-40 gallons a year. As far as a dispenser goes look into Nordson (nordson.com). We have a 1 gallon reservoir and a digital pump/valve controller for dispensing.
