FogCo (or others) Humidification systems questions / RO
Behrmon
Pr. Bear-Mon
Hey all, question for those of you running industrial type humidification systems (Maybe you Gene?). What are you using for a commercial grade RO system to feed your fans? What have you found to be a good fit as far as GPD and Pressure needed to feed these systems? Will be feeding 2 Revolution 2s.
Also in regards to placement, where did you end up putting your fans in relation to your printer(s), these will be specially for an Arizona 2360.
TIA!
Kevin
