I have a customer (friend) who just got a used portable trade show booth. It is about 10.5' long, and 7.5' high. There are vertical magnetic strips that the sign panels (booth wall) attach to the skeleton or structure of the booth.
There are 4 panels 26.5" wide by 88.125" high. They look like they are thin styrene with the print either printed directly or an attached print. Then there is a very nice thick tough matte laminate that is very scratch resistant. On the back of each panel are .5" magnetic strips running from top to bottom on each side. The magnetic strips hold the panels to the booth. On the top left and right edge of each panel there is a plastic hook that is sort of like a large bread tag. These hook onto screws at the top of each side. On the back of each panel there is a thicker plastic strip that stiffens the top and helps the panel keep a nice slight curve. The ends are nice. The left and right end panels attach to the front and back edge (about 12" apart) and the panel curves around in the air creating a round 1/2 tube at each end.
I am looking for a very costs effect way to produce the panels. I was told by another forum member that the lam is probably a matte polycarbonate laminate. I looked up this material and found it to be a little pricey for quick pop up shows that will change frequently. I saw one example of panels that where printed banner material with the good lam.
So my questions are:
1- Laminate materials. What is good and tough (scratch resistant) and cost effective. If there is nothing cost effective, what should I use?
2- Backer material. Can I use banner material? I have a Roland VP540i printer, so I cannot print direct to styrene sheets. Are there other materials that I should look at for the panels.
3- A source for the .5" wide magnetic strip.
4- A source for the "bread tag" hooks.
5- Are these booths generic or are there specific manufactures? If so, what are some brand names?
Thanks!
Thanks!
