TX FOR SALE - 2019 AGFA ANAPURNA H3200i LED PRINTER
DavidOstermann
Let me know if you want to look at this in more detail. David Ostermann 214 566 1999 / mobile
https://www.agfa.com/printing/news/new-install-at-speedpro/
Cost of AGFA Annapurna based on Straight-Line Depreciation (Over 7 Years)
Assuming a 7-year lifespan and zero residual value, the annual depreciation is:
$225,0007=$32,143 per year
From 2020 to 2024 (4 years): Installed in February 2020
$32,143×4=$128,572
Estimated current value:
$225,000−$128,572=$96,428
*with this price, you get
--all AGFA equipment we have (printer, tables, consumables)
--all ink and all 120” rolls of media (3-4 rolls, 1 banner and 1 canvas full roles)
--we will pay to crate and deliver to your address
Technical data
Anapurna H3200i LED
Media & Printing Specifications
Rigid media
Maximum width320 cm (10.5 ft)
316 cm (10.3 ft) with borderless printing
Maximum lengthSupported by 1 rigid roller table: 140 cm (4.59 ft)
Supported by 1 rigid roller table + media extension table (default): 320 cm (10.5 ft)
Minimum sizeA2 landscape (60 x 42 cm – 1.97 x 1.4 ft)
ThicknessMinimum thickness: 1 mm (0.04”)
Maximum thickness: 45 mm (1.77”)
Maximum weight10 kg/m² on printing table (22 lb)
Flexible media
Maximum lengthn/a – restricted by weight and diameter
ThicknessMin. 0.2 mm
Maximum weight0.31kg (0.682 lb) per cm (0.4”) roll width, meaning 100kg (220 lb) evenly distributed over the full 3.2 m (10.5 ft) width
Maximum roll outside diameterSupport for 3” core-media rolls – maximum media roll diameter 30 cm (11.8”) (larger diameter up to 50 cm (19.7”) can be allowed within the distributed weight limitation, in case only print side OUT is used – both unwinder and winder)
Borderless printing flexible media316 cm (10.3 ft)
Productivity
Draft mode
Express mode
Production mode
Standard quality mode
High-quality mode
Up to 129 m²/h (up to 1,388 ft²/h)
77-87 m²/h (829-936 ft²/h)
39-64 m²/h (420-689 ft²/h)
23-34 m²/h (248-366 ft²/h)
9-19 m²/h (97-205 ft²/h)
Print Heads & Inks
Print heads
  1. 6 Konica-Minolta KM1024i-heads: 1024 nozzles/head with a droplet volume of 12 pl (colors)
  2. 2 Konica-Minolta KM1024i-heads: 30 pl (white in line)
InksCMYKLcLm + white
Image & Text Quality
High-quality printsUp to 720 x 1400 dpi
Text qualityPositive: 4 point / Negative: 6 point
Engine Weight & Dimensions
Printer dimensions (H x W x L)177 x 572 x 193 cm (70 x 225 x 76”)
Weight2,800 kg (6170 lb)
Electricity & Compressed Air
Electricity380 V 3-phase star connection with Neutral wire
(3x 32A*) 50/60Hz
230V 3-phase delta connection without Neutral wire
(3x 32A*) 50/60 Hz
Compressed airOil free (class 1 according to ISO 8573-1 2010), 160 l/min compressor with 50 l barrel @6bar
System Integration RIP / Workflow SoftwareIntegrated production solution with Asanti, third-party RIP integration possible
