Malkin
I made a set of files to print / perfcut the current Pantone Solid Color book on our Rolands (using my own design for the actual pages)
I wanted a COMPLETE set of Pantone Solid Coated swatches, as printed by our equipment,
on the media of our choice, etc. The only vector PDF’s I could find online were out of date;
missing many colors, and the values were in the older “CMYK” definitions not the newer “LAB”
definitions. This does in fact make a difference, since when printed the same spot color won't match. (As far as Pantone is concerned this isn't an issue. One either is designing for offset using real Pantone ink formulas, or one should use the more limited Color Bridge to get CMYK values) For us, and others no doubt, we get the best choice and range of colors by just using the spot color fills and letting the RIP sort it out. And having our own "version" of the colors to pick from makes it easy.
Since no document met my requirements, I made my own.
If you intend to use it, read through my "Read This" PDF first in the zip folder
Hopefully someone else will find this helpful.
https://drive.google.com/file/d/1rEL8VbKvKZEPKKkLc30LD-4qtCcpT9nJ/view?usp=sharing
Zip file is about 28MB
EDIT: Oops, just noticed I duplicated some files, just ignore the extras!
Screencap of design also attached
