Copy of gsp.ini
Here is what I see when I access gsp.ini - no font reference.
[plotters]
; list plotters (max list of 48)
; dev desc=isckey,res,x dim,y dim,dev type,data type,i/o port
; The device discription must be unique in the list, in other words,
; if you have two GS-15 plotters, one on com1: and the other on com2:
; they must have unique names in this list. As an example
; [plotters]
; GS15-1=0.002,0.00,13.25,11,2,com1:
; GS15-2=0.002,0.00,13.25,11,2,com2:
; The dimensions should NOT be limit to limit (bumper to bumper) as to
; avoid the device from beating itself into the wall. And REMEMBER not
; ALL devices are created EQUAL.
; When i/o port is set for a GSP Lan device (GSPLANn), the "n" must be
; set to the plotter's lan device address
; device type code: Based on Plotter/Material Height
; 10- 15 inch HS15
; 11- 15 inch GS15
; 12- 15 inch SuperSprint
; 13- 15 inch 4B
; 14- 15 inch Sprint
; 15- 15 inch SuperSprint with GS emulation module
; 16- 15 inch 4B with GS emulation module
; 17- 15 inch Sprint with GS emulation module
; 18- 15 inch GSX15
; 20- 18 inch HS18
; 30- 30 inch HS750
; 31- 30 inch GS750
; 32- 30 inch SuperSprint w/ HS750
; 33- 30 inch S/750 (S750 interface box)
; 38- 30 inch S/750 Sprint with GS emulation module
; 39- 30 inch S/750 4B with GS emulation module
; 40- 48 inch/ short y
; 41- 48 inch/ long y
; 42- Gerber Router III
; 50- Wild-TA30
; 51- Wild-TA30RF (with Roll Feed)
; 52- Wild-TA40
; 53- Wild-TA40RF (with Roll Feed)
; 54- Wild-TA41
; 55- Wild-TA41RF (with Roll Feed)
; 56- Zund-P1200
; 57- Zund-P1200RF (with Roll Feed)
; 60- ARISTO-AG130
; 70- Gerber Edge
; NOTE: this is the same code used in the *.prm files and
; the preferences file
; data type:
; 0 - GDS data format
; 1 - GSP HS-xx data format
; 2 - GSP GS-xx HS-xx/R data format
; 3 - HPGL data format
; 4 - Lettering Machines in GS data format
; 5 - ARTPath Router Controls in GS data format
; 6 - Gerber Edge data format
; 9 - GSI (Gerber Out) data format
[vinylprinters]
