Fred, thank you for the insight. Are you saying the FX consumables for the most part will be more expensive than supplies for the edge II. Also what are your thoughts on a plotter is it worth stepping up to the envision series over the GSX? Are you using the Omega software? Can you use Flexisign with any sucess for printing/cutting? Again thanks for the feedback.
What I was saying and then checked and modified is that the aftermarket from third party companies for foils was less developed than is available for the older Edge models. In looking at what Advantage offers, it appears to me that the adapter cassette they offer is the primary solution and that all the Duracoat/Apex foils are available for the FX that are also available for the older Edge models. I have not researched what, if anything, Zeronine has done with their foil line.
So in summary, it isn't as much of a problem as I posted initially.
We have an Envision 375 plotter and have very little complaint about it. Being a very fast swivel knife, it sometimes goes a little nuts trying to cut a small ®. But it's a top quality, highly productive cutter. The GS series is a lot slower but some models offer a switchover between swivel and tangential cutting which might be of benefit in some situations with thicker materials.
I have two seats of Omega 3.0 and one of Flexi Pro 8.6. I use Flexi for vector creation and editing and for some designs and layouts. I use Omega for basic stups and for setup and production of all Edge printed work. The reason is simple. Omega was designed from the ground up to handle Edge setups and production. With Flexi its an added on feature. Flexi will do it but the logic of their production is 180 degrees out from Gerber's approach so that I don't use Flexi for Edge work by choice and to avoid confusing myself. You will find if you are new to this that the user base using Flexi with an Edge is minuscule, so if you go out looking for help to figure out how to do this or that, it will be a lot easier if you're using Omega.
