Need Help Gerber Odyssey "stalled" job?
Astro
Graphic Designer
My Odyssey XP keeps saying that all the jobs I send to it are getting "stalled" but I can't find out why or how to fix the issue.
Any suggestions?
I query for the size and length of the loaded material and it sees it and is fine with that aspect. I can send the job over, the screen gives me the "start job" option, I can press that. Then it feeds out the length of material needed no problem. When it gets back to the origin point to start cutting it just automatically comes up with "job stalled" -- I'm at a loss!!
Thanks for the help, in advance!!
netsol
stupid question.
is it usb or serial?
if serial (db9 or db25) flow control mismatch
usb, have you plugged into a usb 3,port on the pc (blue wafer) & it's failing hanshake & query
Astro
Graphic Designer
stupid question.
It's serial -- so, flow control mismatch? How do I proceed to fix it, if you know?
netsol
does it start to move the head?
there are settings
  • Baud Rate = 9600
  • Data Bits = 8
  • Parity = None
  • Stop Bits = 1
  • Flow Control = None
leave the baud rate at whatever it is set at on the gerber
ALL SETTINGS HAVE TO MATCH
on:
the plotter (control panel or dip switches
the control panel settings in windows (device manager>ports>com port> properties>advanced)
inside the gerber software
flow control can be hardware, x on/x off or none
normally best practice is to leave plotter settings untouched and match the other 2
