Gold prints Green
evie
my golds always print green no matter what profile i use. Doesn't matter what media I use, it just comes out green. Mutoh Falcon Outdoor 46" Flexi 8.1
Fatboy
Sorry this will sound like I am insulting your intelligence but have you tried printing in rgb or vice versa in cmyk?
Possibly try mixing a better equation ??
Perhaps, what you see on the screen is not calibrated properly, thus giving you a false reading as to what your end results will be.
ucmj22
I dont know how it works with mutohs, but with rolands, you clean them.... with a swab and solvent.
Fatboy
angle grinder...lol just joking. park it to the left and use a swap to remove.Try not to touch the heads underneath.
evie
I can only print in CMYK, RGB won't print any correct colors on this thing. I got the gold to print after changing the values. Only problem...When I assign a color code that prints the good gold, my blues print on the purple side. If I assign a profile that prints a strong blue, I get green in my golds again.
ucmj22
With a digital printer, you should be designing in RGB. it has a wider color gamut, and will help you achieve brighter blues and oranges. dont change the color settings in your rip or profile, do it in the original design so not to mess with other elements.
J Hill Designs
try printing this using your current profiles and use colors from it when designing
  • PANTONE(R) color bridge(TM) CMYK PC.pdf
