JASmith
GRAPHTEC CE5000 48" PROFESSIONAL PLOTTER CUTTER
The Graphtec professional class of CE5000 cutting plotters update the extremely successful CE3000Mk2 series with improved features. The CE5000 series is also -------, \"greener\" with an electronic design and manufacturing process that minimizes the environmental impact of the hardware equipment throughout its entire life cycle.
Each CE5000-120 comes standard with: a floor stand, rear media roll rack, ROBO Master software, Cutting Master Plug-in, plus Graphtec\'s ARMS (Automatic Registration Mark Sensor) system. Professional, reliable servo motors.
Cutting vinyls and contour cutting pre-printed media from most any laser, solvent and water-based inkjet printers are what Graphtec cutting plotters are reliably famous for.
On the job, the CE5000 series offers real cost/performance advantages over other brands of cutting plotters. With faster cutting speeds and higher cutting force, you\'ll have the flexibility to handle a wider range of material. The USB 2.0 high speed data interface or RS232C Serial Port ensures a reliable connection to the computer, either on a Mac or Windows PC.
The CE5000 comes with ROBO Master Pro design software (Windows 2000/XP/Vista/7) and the completely new Cutting Master 2 Production Manager and Plug-in for the latest versions of CorelDRAW and Adobe Illustrator on Windows. Adobe Illustrator plug-in available for Macintosh systems.
The CE5000-120 series delivers a maximum cutting force of 450 grams and a maximum speed of 40 inches per second (in all directions)!
The built-in front control panel provides complete parameter control including eight preset cutting conditions, as well as advanced features like tangential control mode, down force offset, pen up speed, blade wear monitoring and more. With a 25 pin RS-232C or the High Speed USB 2.0 control interface, the CE5000 is compatible with legacy computer systems as well as the latest PCs available now and for several years t o come.
Asking $2,999
Buyer will be responsible for picking up or shipping the plotter
Asking $2,999
