Graphtec CM5 tiling
Humble PM
Mostly tolerates architects
I've got a 2 metre round cut vinyl graphic to do - CE6000-60 using Cutting Master 5 (I know, should have stopped at CM2/3). When I have a weed border enabled, it seems to cut twice though the panel edges, which leads the cutter to want to skew, as the rollers are gripping semi-disconnected media.
On the plus side, when I baby sit it, I'm saved from trimming down the length, and makes checking the panels line up right; almost a perfect perf cut. Almost, but moments away from the whole lot crunching.
Media is Metamark MD4 matt turq, though I don't think this is the problem, rather the double cut.
Should I just RT fine M?*
*Yes
