We have been fighting this problem for over a year. We can send 20 jobs and everything is fine. Then suddenly in the middle of a job the blade gets "stuck" in the down position. If you grab it you can lift it up fairly easily, however when you let go it goes right back down. Case in point (happened 10 minutes ago) I was sending 110" long jobs on 50" 751. The first three cut fine. Then at the last two feet of the fourth job it started cutting all the way through the vinyl and the backing paper. No lifting between letters, just one continuous cut.
This plotter is several years old, we are more than aware it needs to be replaced. My question is, is there a way to fix this, even temporally to get through the next few days?
I am attaching a picture to illustrate what just happened. It was cutting a large "P" and then it started going haywire and never lifting the blade. As you can see, it cut clean through the material.
