Grey looks purple in sunlight
ChrissyF
Hello,
I have a grey logo that I blended in PSD and used a bevel & emboss. Printed out It looks fine in normal lighting, however it has a purple tint in the sunlight. Client wants to keep the shading how it is without having the purple hue in the sunlight. Can't figure out why the purple hue...any suggestions please.
Thank you,
Chrissy
eahicks
I find greys tend to either lean to the green side, or the purple side. Trick is finding that middle. Was it a specific PMS or just a color you 'picked' in the PS? When I print any greys, I actually shoot for a near purplish look, then once laminated it is where I need it, due to lam usually adding that touch of yellow. Sounds like yours was too far in the purplish territory.
ChrissyF
I am using Orcal 3651G and my output profile is 3651G Quality 1 so not sure about a profile issue. Color mode is CMYK and I am using color correction.
MikePro
also, how's your nozzle test print look?
Greys are printed using combination of CMYK and if a couple of nozzles are mis-firing, such as your yellow, the heavy C/M greyscale could come-out looking purple for certain.
