Banners Signs Etc.
So everything has been going fine...nothing is new
Problem is... The grommets don't make a solid connection on the reinforced corners of the banners...
we use hem tape so its like 4 banners thick, it won't cut all the way through and doesn't make a great connection to the bottom grommet...it can be pulled apart sometimes..
The hole itself has metal in it and the banner sometimes has to be cut out of the hole
is there a setting on the grommet machine that will make the top cut deeper or line up better with the bottom...it gets all bent up and makes it halfway...or maybe it is cutting too deep
Been using these same grommets for months with no trouble
grommet machine is a no name lever action, red one from grimco
