artbot
i have an issue. (deadlines for monday and now the printer wants to act up!)
my daytona (aka rastek H700) is leaking magenta heavily. i noticed that each time the head carriage goes to the left the negative pressure
drops out then regains itself going back to the right.
no other colors are leaking. so is the leak causing the negative pressure to fall off? or is the negative pressure causing the magenta to leak?
(i'm assuming the magenta is the cause of the negative pressure issue because no other colors are leaking).
PLEASE HELP!
PLEASE HELP!
