Gemini may have discontinued the acrylic brackets because of constant breakage. Switching to metal would have eliminated the problem.
When acrylic is machined, thousands of micro fissures occur along the edge of a cut or a drilled hole. They're practically invisible till you wipe with a lacquer thinner or some other hot solvent, or sometimes when you paint with a paint whose reducer has one or more of the lacquer thinners (toluene, xylene, etc). We have seen acrylic pieces develop significant margins of spidery cracks along a cut within minutes of painting the acrylic with polyurethane.
Even pinching acrylic can cause these stress fractures, pinching such as can possibly be caused by a pop rivet or a tightened screw. Engineers even have a name for the micro cracks caused by pinching acrylic—it's called
creep.
Riveting a metal bracket to the polycarbonate back of the halo-lit letter avoids the possibility of an acrylic bracket cracking from drilling and riveting. It also has the advantage that screws through the returns holding the fabricated letters to the brackets can be removed, allowing easy servicing of the LED modules which remain attached to the polycarbonate backer.
Note in the Gemini drawing that countersunk screws are depicted holding the channel letter to the brackets. A better choice is a truss head screw. It doesn't require a countersunk hole, but still has a nice low profile. A truss head is also a better choice than a hex head to attach trim cap.
Also, note that the drawing is showing a white plastic back rather than clear. Better light diffusion?
You will find that when acrylic breaks, it is often at a fastener. It's because the cracks are already there, just unseen. It's why drilling holes in acrylic is best avoided, if possible. If holes must be drilled into acrylic, the manufacturers' guidelines on hole diameter and distance of a hole from the edges of acrylic should be followed to minimize breakage.
Even the pressure exerted by a "knob-type" standoff can, over time, result in creep, allowing a corner to break off a sign panel from just normal wiping. Finger tighten the cap then back off one quarter is a common rule of thumb.
For generations, acrylic faces have been installed using
retainers only, with no fasteners penetrating the plastic, and with good reason. You can get away with putting screws in the corners of a polycarbonate face, but not in an acrylic face.
Failure from damage caused by creep occurs not just in plastics, but metal as well.
Brad in Kansas City
