Caleab Brown
Hello,
This is my first post here! Thanks to everyone for all the helpful information I've found.
Ghosting
I recently did a head replacement on a VP-540 (it was the black head), and after the replacement, there was some 'ghosting' (that's the only word I can think of that makes sense).
__________________________________________________________________________________________
Alignment
I feel that it's something to do with alignment, because I had an issue with the vertical alignment while doing the head replacement.....
If you've done a head replacement on a Versacamm, you know how you do the bias alignment with the hex key / alan wrench, and you do the vertical alignment using knobs on the front of the head carriage. Well, while doing the vertical alignment, there was no change when I did adjustments. I loosened the screws properly and everything, but no matter how far you turn the knobs on ANY of the print heads, it did not affect the test print. Am I missing something? I feel like maybe the springs on the vertical alignment screws are worn, but I'm not experienced enough to know where/how to troubleshoot.
I'll also attach a before and after picture of the vertical alignment. They look the same, but one is after a full turn on every single printhead alignment screw except black (K).
Conlcusion
That's what I know. If there's any questions please comment and I will try to give a good answer. The two issues may be unrelated, but I really don't know where to go from here. If anyone could point me in the right direction, I would appreciate it! I tried surfing the web, but couldn't find anything decisively helpful, if there's a thread or post anywhere that could assist me, I would be thankful for that as well.
Hope everyone is having a good Friday,
Caleab
Ghosting
I'll attach pictures so you can see what I mean.
Ghosting 1: https://ibb.co/17ndf7p
As you can see, the black text has an odd 'ghosting' above the body of the text. I'm not sure why it's doing this, but I've check the file to ensure it's not originating in the art.
Ghosting 2: https://ibb.co/NTdDTJq
This is a spot on the same print that looks okay. The 'ghosting' isn't really an issue here.
Ghosting 3: https://ibb.co/r6BqwKX
Another spot of ghosted text for further reference.
Alignment
Vertical Alignment 1: https://ibb.co/sbSFtFc
This is one of the first test prints for the vertical alignment, at this point I had only rotated the cyan knob 1/6 turn CW.
Vertical Alignment 2: https://ibb.co/RvSByrL
This is after extreme changes to the C, M, and Y vertical adjustment knobs.
Conlcusion
Caleab
