Conor Knoxx
I have a ValueJet 1204 - 4 years old now, and the only "maintenance" I've ever done is clean it (I'll admit I'm somewhat intimidated by more advanced procedures!)
Its quite a low-volume shop - I'd say a set of cartridges every 2 months...
Recently, the magenta has become erratic. One of the heads (the right hand set when you do a print head test) just completely stops firing, in the middle of print jobs. If I shut it off, then on and do a head cleaning, it "comes back to life" every time - while other times, it suddenly will put a light magenta "sheen" over the whole area its printing (like its firing continuously) - again, if I shut it down, and restart, it seems ok for a while..
I'm ruining about 25% of my print jobs now though, so I can't just "live with it" anymore. The company I bought it from no longer deals with mutoh, and I haven't even found a good place to get parts (I'm in Eastern Ontario Canada)
The second problem (not as critical...) is the cyan head - again, the right-hand one - on a print head test, leaves exactly 50% blank - eg: instead of solid/stepped lines, I get dash - space - dash - space thoughout its pattern.
Any insight or help sure is welcome!
Thanks in advance!
Conor
Thanks in advance!
Conor
