HELP LOL Head issues
PMG
Mutoh 1204.....would a head just stop printing all together when the life span runs out? i know im due for a new head but..... the issues im having is i had a EO74rr CR2 Current error alarm at the end of a print....so i shut it down and unplugged it for a wile....when i fired it back up and went to print ,it would act as if it were printing but will not lay any ink down. i tore the machine down and looked at all the fuses and all are ok......im lost .....all the ink levels are good and lines are full and when i do a cleaning you can see ink draining...im lost :frustrated::frustrated::frustrated::bushmill:
randya
No, the counter is just that, a count of nozzle firings stored in a data base, then that hits the magic number, it just gives a warning. It is all based on MTBF analysis.
F2 fuse is probably #1 reason.
Could be the head died,
cable died or is shorting
head driver board
mother board.
Check and make sure of the f2 fuse location.
PMG
Randy from what i see on the main board is a lil white ceramic fuse about 1/16 x 1/16 square and it is on top soldered to the board...this machine is from 2006....so i dont think it will have the newer fuse setup am i correct...if what im looking at is the fuse it dont look blown. no dis coloring or broken .
tsgstl
I'm in O'Fallon MO with the same printer from 07 if there is any reason looking at a working 1204 would help solve your problem let me know.
good luck
randya
These kind of fuses wont look blown, you have to measure continuity.
Yes, I think your fuses are all soldered on.
It takes a little skill and the proper soldering iron to change without causing damage to the MB.
PMG
good luck
ThanksTSG....i may be Pming you to send out a few jobs....if i dont get this going soon.
PMG
thanks for your help Randy....guess i better break out the meter reader LOL.
