Colleen
Noobie
Been using Oracal 651 for a quite some time now and haven't had this issue until a few months ago. The vinyl won't stick to the application tape. On big and small cut pieces. I've been trying to do all sorts of test cutting and ordered new transfer tape as well, and it's still causing me issues. I've tried Transfer Rite Medium Tack and Nekoosa High Tack with no luck.
Before I never worried about the cutting force (Cutter is Camm-1 GX-24) because I was never taught to change the force when cutting vinyl. But since this issue has started I've lowered it from 100 to 90, 80 and 70 and it's still giving me issues. I'm not the only one who uses the cutter, so I'm not sure about blades. But I'm thinking it's the application tape. Any ideas? What transfer tape brands would be best to use that isn't too expensive? Thank you!
